Text originally published in portuguese.
The air conditioning Window-Split is a mixture of traditional window air conditioning and split air conditioning, or you can have all the technology of a split installed in a ordinary wall opening.
Some manufacturers offer this innovation in air conditioning, very suitable for those who are interested in installing a split air conditioning and are impeded by compromising the structure of the construction or modify the aesthetics of the facade.
Description of Air Conditioner Window-Split
Window air conditioner Split is a device with the outside (condenser) reduced and also more practical and functional than the common models of window.
So, it appears the biggest advantage of the split window to install a split unit into existing spaces in the wall.
For convenience, the external drive is the same size as traditional models of the window (in some cases will need to adapt / change the size of the opening in the wall) and the internal standard has the same models splits: filtration system, remote control without wire, etc.. (Check out the photos immediately below)
Price of Split Window
The value of a split window is slightly larger compared with the traditional split by having better technology and reducing the size of the condenser.
Device characteristics split window:
Note: Not all models have the features listed below. Consult the manufacturer or seller.
– Available in powers of the 7000btu 12000btu cycle in cold and hot and cold.
– Remote control
– Bio filter
– Rotary compressor
– Condenser Corrosion
– Control of air flow
– Easy electrical connection
– Swing Mode
– Sleep Mode
– Steerable fins
– Dehumidifier
– Fans efficient and quieter
– Self diagnosis
– Auto reset
– LED Panel
– Optimal filtering
– Lower power consumption
Summary of Air Conditioning Split Window:
– The external drive is the same size as traditional models of window;
– The indoor unit follows the same pattern models splits;
– They are quieter when compared with common windows air conditioner;
– Can be installed in existing spaces;
– Got remote control.
Photos:
http://www.webarcondicionado.com.br vale a pena visitar todos os dias
Estou muito contente ao ler http://www.webarcondicionado.com.br !
Preciso comprar um split window pois no meu prédio temos a estrutura de ar- condicionado parede; gostaria de saber marca e preços disponíveis.
Grata
Jane, no link a seguir você encontra as marcas Elgin, Midea e Komeco. Os preços variam de R$815 a R$1410 http://www.webarcondicionado.com.br/?mo%5B%5D=18&pg=1
