Text originally published in portuguese.
You are buying an air conditioner split and doesn’t know how it is done installing? Watch these two videos that we selected for you, they show the steps of an installation. One is in English and the other in Portuguese.
This first video gives a sense of being very easy to install a split air conditioning, but we advice you to not do this procedure if you have no experience in installing air conditioning.
What you will find in the first video: Presentation of the product, description of the interior, installing the evaporator; Fixing the evaporator inside the environment; Description of the outside (condenser) Installing outside; Connecting the condenser to the evaporator; Turning the split.
Video 1:
Source: joeypsu Channel on youtube
Video 1 Comment: Very well done, but failed to show the vacuum.
Video 2:
What you will find in the second video: Preparation for installation support of the condensing unit, condensing unit to the mounting bracket; Attaching the bracket from the evaporating unit; Hole on the wall for passage of the discharge tubes and suction gas; placement of terminals on cable connection between units; Grip Crimp terminal; Fixing the evaporating unit to the wall; connection pipes, drain hose, drain flow test; connection pipes; Placement ground terminal; shrink insulation; Placement air filters; Execution vacuum with vacuum pump;
Source: Channel helber1020 youtube
You filmed your installation? Send the link to us!
What is your opinion on the facilities shown in this topic? You do differently?
We await your feedback so that our conversation can continue.
