Text originally published in portuguese.
You are wondering “How do I clean my air conditioner Split?”
This material will help you clean your air conditioner split. We specify some items to help you:
– Why clean the filters of the split air conditioning;
– Clean the filter of activated carbon and HEPA filter;
– Cleaning nylon filter;
– Indoor unit: Remote Control, cover, front panel;
– External unit: condenser;
– Tips for various resettlement and care.
If you have questions, tips, extra information, videos, etc.. You can contact me via the form or leaving a comment.
Why Clean?
When the air filters get dirty, reduce product performance and worsening quality of air you breathe.
Clear once in a month or more frequently if necessary.
Watch out the socket!
Remove the cable from the outlet before cleaning.
INDOOR UNIT
(Remote Control, Tampa and front panel)
– Use a dry cloth to wipe the indoor unit and remote control.
– If the indoor unit is very dirty, use a cloth dampened with water to clean it.
– The front panel of indoor unit can be removed for washing. Remove it carefully. dry with a soft, dry cloth.
Care!
– If the indoor unit is very dirty, use a cloth dampened with water to clean it – without chemicals.
– Never use abrasives or polishes to clean the unit.
Filters
Step 1 – Removal Filter
– Open the front panel slightly to get the filters;
– Hold the handle of the air filter and lift it slightly to disengage it from the filter holder.
Watch a video of how to remove the filter from split air conditioning
Step 2 – Cleaning of Carbon Filters and HEPA
-Check for Activated Carbon Filter (left) or HEPA filter (right). Only a few models have these filters and remove them before washing the nylon filters;
– The manner of removal and installation of these filters is different between models;
– There can be washed with water, wipe them using a vacuum cleaner or Overwrite them;
– Clean the filters of activated carbon and HEPA once a month and replace them by another every four or five months.
Care!
– Do not use water, just clean with a vacuum cleaner.
Step 3 – Cleaning Nylon Filters
– Hover vacuum cleaner;
– Wash with warm or cold water, and if necessary use mild soap;
– Thoroughly dry the parts in the shade;
Care!
– Never use abrasives or polishes to clean the unit;
– Do not use chemicals;
– Do not wash with water above 40 ° C, Damages filters and plastic parts in general
Step 4 – Resettlement
– Don’t turn on the air conditioner without filters
OUTDOOR UNIT
Condenser
– The heat exchange coils and panel vents of the outdoor unit should be checked periodically;
– If clogged with dirt or soot, the heat exchanger and the openings of the panel can be steam cleaned,
by competent professionals;
– Clean dirt, leaves and debris;
– If there is any point on the external drive rust, apply a bit of synthetic enamel paint to prevent its spread;
Note:
– Dirty or clogged coils will reduce the operating efficiency of the system and cause higher operating costs and energy consumption.
